Transmission problems, Need help
Jaredkeller96
Crawfordsville Indiana
Okay so when I put my truck in Reverse, 1st or 2nd it takes off without throttle, if i put it in Drive it barely moves with throttle?? What's wrong?? Has a new torque converter,
So fix this one? Or replace first gear in a trans we got In the garage??
Sent from my iPhone using Tapatalk - now Free
Jaredkeller96
Yes it is, may be my wiring cause I had to swap the pins into a different connector, the plugs were different from the idi to powerstroke plugs, may swap solenoid packs and harness
Mark Kovalsky
SE Florida, USA
I might see it here.
If the wiring is wrong the solenoids will be applied wrong and the trans may not be in first gear in drive. In 1 and 2 the hydraulics circuits override what the solenoids are doing so it can work normally.
Fix the wiring and see what happens.
