truck shut off at the end of a pull
Stroked777
Casper, Wyoming
i was pulling tonight had Gear head tunes loaded up with econ trans file, the truck pulled great and when the red flag flew at the end of the run i let off the throttle and the truck just shut off, this is the first time its happened to me and it did it both times i pulled a few hours apart. it fired right back up and there is no CEL, anyone have any ideas to why it shut off?
ncdzl
Any chance you ran out of fuel psi?
simonton6.4
Monroe,Ga
Mine does the same thing every time I pull it was explained to me that there is to much air coming into the cylinders when you let off that hard with no bov it rushes the cylinders and there is no fuel there to ignite the amount of air so it snuffs it out and truck shuts down. Doesn't hurt anything kinda embarrassing every time but nothing to worry about from what I understand
7.3powerstroke00
Brownwood
Tq converter still locked killing it? Had a 7.3 with 4r100 that would die from converter lockup. Idk I haven't had any dealings with 5r110 since mine is manual.
Stroked777
Casper, Wyoming
i could see that happening, it fired right back up and ran fine after, im not worried about being embarrased lol, it was so lound there no one caould the 6.4 shutting off and firing back up
Oil Field Trash
Jonesville MI.
Yeah that's right. As I'm getting out of the throttle at the red flag I never let out of it completly I let it come down 1/2-3/4 throttle and then bump it back up a 100-200rpms so it doesnt snuff out
Stroked777
Casper, Wyoming
so if i was to get a BOV like plan on doing when i get a 72 atmo, that will cure the problem?
WoodBoy
Alabama
Definitely make sure you fire it right back up and don't let It sit when that happens to keep from cooking your oil
Ipkyss
Torque converter should be locked or your pulling with the wrong tune. My truck does the same thing if I just let off the throttle. If I touch the brakes first and let off a little slower, it will never stall. My 6.0 was the same way.
why is the TC unlocked?! that's why the egts are crazy.
simonton6.4
Monroe,Ga
Your only doing 36psi what tune are you pulling in? Should be brighter then that and those egts are a little high I think man I mean mine get high pulling but I haven't noticed them getting that high up there unless I just wasn't paying attention this is got me interested I need to datalog next time I pull and see what mine is doing
Stroked777
Casper, Wyoming
i was pullin in Gearheads race tune
im really starting to think the river city diesel cam i put in has done jack chit. looking at the cam next to the stock one it looked different but the lobes were shorter than stock and they claimed the lift on the new cam was 2x what stock lift is, honestly i think i wasted my money buying the cam
simonton6.4
Monroe,Ga
Well I can't say anything on the cam haven't seen one or done any measuring on it but I pull in the same tune and I really can't think of anytime where my temps was over like 1300 something, might of been a little higher but not coming down from the 1700s
If the cam is a smaller lift then I could see where temps would be getting way out of hand maybe someone will chime in on that man iv heard good bad and nothing at all on the cams iv been looking at them just to increase my rpm rang but still haven't found any real good info on that it does that
