truck shut off at the end of a pull
Stroked777
Casper, Wyoming
Well I can't say anything on the cam haven't seen one or done any measuring on it but I pull in the same tune and I really can't think of anytime where my temps was over like 1300 something, might of been a little higher but not coming down from the 1700s
If the cam is a smaller lift then I could see where temps would be getting way out of hand maybe someone will chime in on that man iv heard good bad and nothing at all on the cams iv been looking at them just to increase my rpm rang but still haven't found any real good info on that it does that
They claim it was .405 lift but looking at the rcd cam next to the stock one it looked like the lobes were smaller
simonton6.4
Monroe,Ga
Idk man wish it wasn't such a pain to get out I'd say measure it I'd like to know what is actually going on there makes me real hesitant on buying one
blk350on20s
It has nothing to do with air. It is your converter still locked and it goes to zero tire spin. Stalls out. A BOV will do nothing for you except stop bark. Like stated above tap the brake pedal which unlocks the converter or let out slowly. I want to say some people throw it in neutral.
FordPSD64
San Antonio, TX
just don't slip and go to reverse by accident LOL
Ipkyss
I do know people that shift to neutral, but if you mess up and shift to Nuetral under boost it will blow right past the rev limiter. Tapping the brakes is the easy safe idea.
Athens, IL
Not trying to be a dick, but do you know anything about cams? A regrind cam is alway gonna look smaller. You obviously can't add material with a cam grinder. By grinding the backside of the cam lobe you will end up with more lifter travel. It all has to do with the base circle and where the lifter sets on the back side compared to where it is at full lift. You can't look at it and tell. Did you get your other problems fixed with the truck? Or are you still just blaming the cam for no unjustified reason? If you only made 36 psi boost you obviously have a leak somewhere, just like we stated in your other thread.
If your going to keep saying that the cams the problem find some proof. I've put in a lot of cams and never had one cause problems. But you said you had a squeal and your low on boost. There gotta be something wrong with your truck. I know what the grind is that's in your truck. There is no possible way that it is hurting your truck. Otherwise stock cams would be hurting your truck because there isn't much change from stock. It's a stock stage one cam made to drop in.
Oh and to answer your dying issue. Most all engines will dye if you go from full load all that air and fuel to nothing like that. That's why most of all the big trucks rev them up at the end. If I let mine snuff out like that it almost hydra locks. I would either bump to neutral or let off and blip the throttle a couple times as it comes down. But the dying isn't anything abnormal at the end of the track.
