OP my truck was running a good while with 0 PSI on the fuel pump but my fuel bowl would still fill up. Guys on here said the injectors would still run the truck, but just be hard on them.
I replaced the fuel pump and got 55psi immediately.. so the guage/schrader valve wasn't a fluke.
Also for all guys talking e-fuel. New Carter pumps on RiffRaffDiesel are $92. I'd much rather have my truck fixed for $92 and then convert to e-fuel. In my case I also had other issues aside from my fuel pump.
I had a new carter pump fail in less than 6 months. The electric pump had a huge advantage to be changed roadside much quicker than trying to change a mechanical pump. The electric pump also does not pulsate like a mechanical pump and can prime a syatem much easier. Highly consider working towards efuel. I'd you build a kit yourself it's not that expensive at all. Also low fuel pressure is not just hard on injectors it can permanently damage them. Most notably low fuel pressure can score the plunger and barrels and they will need to be rebuilt.
