Truck update.....
powerstrokedub
Utah
Truck looks awesome man! I have a set of tinted tails that I just took off of my truck cause UT laws are so strict if your interested.
SouthFlstrokin'
Thanks guys I still have a TON of work to do, but I think she's coming along nicely. Pretty sure I'm going to slam it now. Just not sure....
David S.
looks so good! rollpan looks killer, gotta slam her now!
hopefully the injectors will give you the power your looking for as well
SouthFlstrokin'
Update:seized up caliper. Wasted rotor.
Question... Should I replace both front rotors? Anything else other then pads and of course a new caliper?
SouthFlstrokin'
Oh also the caliper sprayed brake fluid all down the side of the truck, of course after I just put all the new painted parts on....
Agjake11
Rosenberg TX
Since your 2wd rotors won't be cheap only replace one unless both are needed. Do pads and BOTH calipers and flush.
Did you take the caliper off already? If not open the bleeder and see what happens to make sure it's the caliper
