Truck won't start
Rmartin-97
Mcarthur ohio
I had my cab off and now I put it back together and it won't start. A dashdaq says I've only got 445 psi of rail pressure is there. Plug or something I forgot
907DAVE
AK
What was done when the cab was off? Any fuel in the oil?
Alfie
Horrible state of CA
I don't see how's that possible since you didn't mess with any fuel lines. And your getting no air from the bleed tool? You are using the ford bleed tool right ? Sorry have to ask. Good base fuel pressure at the fuel cooler right with no aeration there ?no codes? Other then low ICP codes? Your down to an injector bypassing through the return side, HPP, or injector leaking through tip, injector /s tube leak. Mmm weird
webb06
Seneca, MO
He had to have the lines running from the pump over to the fuel rails off right? Since the rocker boxes were off?
