Truck won't start
Alfie
Horrible state of CA
Oh you did remove the rocker box ? I thought u did just the cover gasket. Then I would make sure an s tube isn't leaking
White_monster
The great white north
Like buddy above me said, check the tubes from the rail to injector. Did you reuse the lines you removed? Was anything else removed under the valve cover besides fuel tubes, rail and rocker box?
Alfie
Oh. Never reuse these lines. Most likely they may be leaking. You can get a new set of s tubes at the dealer. And don't over torque these lines.
bigrpowr
<How I Fly
Administrator
yeah thats scary!! dont reuse those lines !! cuz when they do leak while pump is turning you dont know it , and you end up with a really shiny bottom end !!
