20007.3stroker
Bumpin this back up.
I am betting on tired injectors.
Ok guys finally got a buddy over here with his solas. Truck decided to run better, but still has a miss and somewhat acted up. Got some codes and some data:
codes before we even started p1280 and p1211
CC had no codes and buzz test had no codes
At idle icp low to mid 500 ipr duty cycle 14%
WOT icp high 2700 to low 2800 ipr duty cycle 41%
We did multiply checks of both icp and ipr duty cycle to verify and 41% was the highest the duty cycle got.
Bad IPR?
Did you ever check your fuel pressure?
