Dirtclod
Thanks for the info
didnt you get the pcm from Justin? id keep fuel pressure between 60 and 65 psi.Thanks for the info
I just installed this chip an hour ago, it works like a charm but i sure wish i woulda bought an intake first.......it threw a code due to my filter being clogged..... buying an intake today......2002 f350, any suggestions as to which make/model will work best?
Honestly didn't read through all of this, but I had surge after my injectors and tunes.... went with a WW and it took care of most of it. Noticed it a couple times towing the toy hauler (roughly 10k loaded) passing people up Monteagle (several mile long 6%+ grade). LOLI have a question and figured I'd just add it to this thread. In a week or 2 I'm going to pull my travel trailer from NC out to San Jose CA. I'd rather go ahead with a php hydra chip but I've found a ts 6 chip with selector switch new for 150$. The extra fuel mileage should make it worth the investment. I would love to change to a t4 setup and s366 turbo but already having to get new stickers and try to straighten out the front suspension good enough for the trip. ( the axle swap will have to wait) I'm going to need something for my turbo. It surges,barks,shutters,farts and carries on when pulling and the last time I ran this chip it was horrible. Sounded like it was going to blow off the engine. What's the cheapest and most effective solution? Banks upgrade? Just a compressor wheel? Or should it be rebuilt? Who to go with?
