sniper_101
I havent used it yet but can I erase selected positions on the chip and burn new tunes from a different tuner onto those select positions and leave the previous tunes in-tact?
Thanks
Thanks
No if you just burn position 1 an 2 uou have to take the little metal deal off below the knob and change it to just two Settings.
More than likely you need to clean the connections and be careful because the current condition can cause chip and pcm failures. Also you can fill the remaining positions with the same program as position 2 to prevent accidental stallingTwo quick questions. Its alright to have tunes loaded to position 1 and 2 and leave the rest blank/erased?
After reinstalling the chip the wait to start light and parking brake light randomly won't light up when I cycle the key to ON. It works fine 100% of the time without the chip plugged in. Is this a connection issue or can this be an issue caused by tuning? (I dont believe so)
Thanks
let me know if you need tunes!
Thanks for the offer POWER-STRUCK.
Groomzybanshee has saved my vacation with some tunes that should do just fine. A stand-up guy, thanks again!
