TS problem
Lamont_24
Edwardsburg, MI
Well it's not the TS, it started fine today and it was running for about 5 minutes and it's about 26 degrees out. I back out of my parking spot at my dorm and then start driving and I see the check engine light come on then it started running like **** and so I pulled into a parking spot and it died. And I recorded trying to start it back up. I had my foot to the floor the whole time unless it revved up and I let off a little bit. I just started school so I don't know anyone with a good scanner so I went to autozone but there scanners can't look up history since the check engine light went away. So I'm working on finding a quality scanner at school I can use
http://youtu.be/wcz1dAvaELU
85_305
The fuel has gelled and the trucks running like **** because the oil is too cold and sluggish. Start using the white bottle PS during winter, and give the truck 1-2mins to warm up and dont let it go over 1600rpms or so to prevent that issue you are having.
Lamont_24
Edwardsburg, MI
The problem was the fuel pump going out
d7es3l
Colorado
Before I switch my truck to high idle, I let it run for 2-3 minutes. Then I kick it to high idle!
