So I got my PHP Hydra installed last night and took it for a spin. After hearing many stories of people having a permagrin after taking it for a spin (PHP or DP Tuner) I was looking forward to it.
However, I can't honestly really tell much difference, on 80HP Daily Driver
Normally I would think that the tuner isn't working,
but the whisper mode and high idle I put in work just fine. When switching between programs, it flashes as it should...no errors or anything erroneous that would tell me its not working. The truck works just fine.
My truck is a 99.5 f-350 with the ZF6. Truck only has 129k on the clock, so a weak HPOP or injectors doesn't seem likely to me.
Since I can't just get on the go pedal and go WOT, I'm wondering if it's harder for me to notice? I would however THINK that a 30%+ addition in HP (though in reality probably not a full 80 since I'm running stock injectors, turbo, and HPOP) would be rather noticeable in the SOTP feeling.
It does look like the previous owner had something installed. When I pulled the PCM, someone got over zealous in cleaning and pretty much all the pins were down to copper. While I might think this has something to do with it, I've read numerous other people saying they got overzealous and it works just fine, and I'm not having any issues with no start, and error codes, etc. I used to correct tuner codes, as I made sure I was using the correct hex code for my PCM.
So, anyone have ay experience with this? Is there an easy was to tell if the tuner is giving the output, and the PCM using it as it should?
