tuning 64mm streetmax
Stangr8cr
I have a couple questions for ya on Monday Morgan, just want to make sure my tunes will work with the street version of the MM. I know we talked about my tuner being the street version but I think I forgot to send it with the base files email and just want to make sure the tunes will work when they're done?
Keith
Athens, IL
Is that what I will get with your tunes
No, you will not. I will not guarantee or "label" any tunes we sell as XX hp tune. That is a generic crappy way of labeling tunes and it sets you up for people who don't make XX hp to call and complain. Every truck is different. You will have to dyno your individual setup to find out. You may make 600 you may make 550. The truck that made over 600 on a stock pump was mine. But it has everything that exists on it to get there. Maxing out the stock pump until rail pressure falls is a good way to destroy a cp4. And I will not sell that. On top of that, at that power level I destroyed my transmission by leaving it tuned high and beating it.
You will get the tunes that are safe and proven for the pump and the trans. The same tunes we sell to everyone. We are not custom tuning each and every single individual truck. It is not needed and will cost even more money. If that is what you want you can keep going back and fourth with who you have until your happy (which I believe is not what you want, hence why you started a thread). We are selling tunes that are produced to work and perform safe as possible at these power levels without codes or issues.
Keith
You don't have anything to worry about. You sent us your base files, that is all we need. When we send the files back they will load directly back onto the tuner they came from.
Stangr8cr
Cool, just wanted to make sure I'll still be able to run deleted with the street tuner, thanks Morgan.
Keith
spanky24365
massachusetts
He's telling me now it's sone thing physically wrong with my truck that it's not in the tuning. I have no issues with the tow file. Lights come on with performance and race files. If it was something wrong with the truck say a sensor wouldnt it happen it all The files
ChattyCathy
Did the truck do this before the turbo? Was the truck tuned before the turbo?
Buck1
Winchester, IN
Beleive I started getting the same code with my Tow max after I switched tunes. I have a new Map sensor and gonna try that. Will advise.
Sent from my VS985 4G using Tapatalk
