I did 1600+ up at 100%
Nov 5, 2015 #21 C CoreyMS New member Joined May 5, 2014 Messages 108 Reaction score 0 I did 1600+ up at 100%
Nov 5, 2015 #22 T torque beast Member Joined Dec 22, 2013 Messages 375 Reaction score 1 Here is what I did, one going off stock profile and one raising top to 100% Stock Modified
Nov 5, 2015 #23 2 2012dually New member Joined Sep 28, 2015 Messages 24 Reaction score 0 Location Canada If none of the fuel or boost tables torque axis goes above say 1000, why would you have your pedal to torque map at 1200? Looking at your pedal to torque map you would theoretically be commanding full torque at 52% pedal position and 2000 rpm
Nov 6, 2015 #24 T torque beast Member Joined Dec 22, 2013 Messages 375 Reaction score 1 2012dually said: If none of the fuel or boost tables torque axis goes above say 1000, why would you have your pedal to torque map at 1200? Looking at your pedal to torque map you would theoretically be commanding full torque at 52% pedal position and 2000 rpm Click to expand... Ya that is one of the questions I had. Doesn't make sense but the H&S box tune had 1174 in there as well. Not sure if it's right or wrong but I'm like you I don't see a need to go above what's in the axis Sent from my iPad using Tapatalk
Nov 6, 2015 #25 T torque beast Member Joined Dec 22, 2013 Messages 375 Reaction score 1 Also, my stock table shows a high of 991 but that could be screwed up too as most of my stock tables had issues
