Tuning the 7.3 in current times
Powerstroke Cowboy
Montana
That's sounds like a lot of haze. Cold my 300/200s will have but after the engine is warm, they run clean.
Does your engine use oil between oil changes?
I want a vgt as well as compounds. lol
INFRNL
Colorado
No, it doesn't use/ burn oil...maybe amounts in milliliters but nothing out of the ordinary. Yeah, the amount of haze is enough to call the hazmat team. It does clear up some as it starts warming up and not too bad once warm and has been driven.
I wonder if that has anything to do with my poor mileage with the 250's. I've had crap for mileage since going T4
My engine only has around 15k mi or so since being rebuilt....I'm starting to think my math is incorrect on mileage of the injectors; it has to be closer to 50k but that's irrelevant.
I am never the lucky one, everything is out of the norm for me usually. But the important thing is my truck has been extremely reliable. I haven't had anything happen really besides normal wear parts wearing out. Performance parts have't had long lives but no major failures or issues like you see people asking about over and over. My truck always fires right up and gets me where I need to go without issue.
I would imagine your truck would definitely benefit from VGT and/ or compounds. I'm really hoping KC turbo's eventually makes a VGT for the 7.3...I'd drop my T4 setup in a heartbeat. With his gen 3 turbo's I question if he might actually be pulling ahead of BW now. He's currently working on a give away truck with 238/80's that seems like it would walk all over my truck and he hasn't even upgraded much of anything else yet. I think he did turbo/ injectors, tranny and fuel pump...and broke 500HP to the wheels.
I feel like my truck is a turd now...it does do good now on the bottom end and under normal driving, boost is much smoother
Mesa, AZ
When you had your engine built, did you put cut pistons in it?
INFRNL
Colorado
I believe it's just a standard rebuild, IDK. I had head studs added, beehive valve springs, smith bros push rods and a colt cam.
I will say after the rebuild it seemed to have less torque on the bottom end at first stab...but that's a different delima and I wonder if it's from the cam
It's also got factory forged rods now
Mesa, AZ
Cam could be causing that, or a boost leak.
If you had cut pistons, I’d blame the idle smoke on them, as we’ve got a truck right now that’s going the same thing. And my 6.0 does it a little when warm, a decent amount when cold.
INFRNL
Colorado
Definitely no boost/ exhaust leaks.
Ah...I thought you were leaning towards I need cut pistons...I believe I'm safe there.
Today I fired it up to go to the store, first time in a couple days and it was pretty warm today. Very minimal haze today and it cleared up quickly.
If i ever get to my project truck, I think I want to try your Gen 3...might have a gen 4 by that time...in comparison to my SX-R. Downside to the comparison is it'll be a ZF6 in a 76 F350 Crew cab 4X4 vs my 03 7.3 CC Dually with built 4R100. Not a fair comparison.
do you guys have startup/ idle haze on the give away truck with the 238/80's? I don't think Charlie has show that in the videos
Mesa, AZ
No, no idle haze in the giveaway truck, at least not an ungodly amount. There’s a little puff when it’s cold, at least for us, and then clears up pretty quick.
The truck we’ve got at the shop with cut pistons, will just sit there an smoke at idle in 90 degree weather, and when Charlie drove it to the shop I’m in from our main shop, which is about 20mi, he said it took about 10min of cruising to finally stop hazing.
INFRNL
Colorado
I don't think my truck is that bad. IIRC since the rebuild the 250's will haze a little even when its warm outside until I drive it a bit.
Before the rebuild My original stock injectors would't haze only the 250's. Then after the rebuild I had a different set of stock injectors that would haze when cold but I think only during the cold months. There were various reasons for going back to stock but mainly because the haze during the winter is so bad ad we have a lot of kids in the area.
I've been dealing with the haze for the past 13-15yrs; you never really get used to it and it makes you look bad when people see it but don't understand the reasoning
