Turbo and dual fueler for 50shades
stacked6.7
What are you guys using for boost gauges? I'm assuming by factory you mean what the mini maxx reads.
Houston, TX
So we will be installing a sump and running a fuel lab to feed our cp3. Thanks to Chris B at TSD for the hook up on the parts. Very helpful group of guys. I'll be running two separate fuel gauges also to monitor both systems. When cruising every now and then it throws a low pressure fuel code and warning. Don't wanna damage that cp3.
Sure this will fix that issue.
4EverBoosted1
You need to un plug your pressure sensor on your driver side fuel rail. It will throw that low pressure code even if there is nothing wrong.
Sent from my SAMSUNG-SM-G900A using Tapatalk
bigrpowr
<How I Fly
Administrator
You won't hurt anything , it's just yelling at you for going under 55 psi. Not that big of a deal. As well , update your tunes from hs , that code has been dealt with. You certainly won't damage that cp3 , it only needs 12-15 psi , it's the cp4 that needs the high pressure.
smokinstroker
Texas
Good to meet you yesterday Dorian. Truck sounds great, going to need a ride in that next time I'm in houston.
4EverBoosted1
I saw your setup and kept the pictures. I was thinking about doing the same thing. Did you put the output of the second pump into the unused port on the H&S fuel filter head? Not sure which way I am going yet.
Yep I sure did. The pressures are equalized at the fuel head.
Houston, TX
With my two factory LPFP's I see 40psi out of both of them at all times.
like this! Lol
4EverBoosted1
Nice. How about the electric. Added another relay switched by the key?
To be honest, you would have to contact MorganY for info, I was welding while he was making the harnesses for it...
