nossliw
- Joined
- Jan 26, 2013
- Messages
- 88
- Reaction score
- 0
Fantastic advice!
In all of the threads on the KC 38 I have yet to find one of a compressor map for the unit. Can anyone assist and post. What is the peak flow currently advertised?
I'm glad you replied. I was going to say something very similar about your business size vs Garrett, Borg Warner, etc. But I didn't want it to come off as insulting. Smaller companies don't have the R&D budgets to pay to get compressor maps built.
I guess I hadn't even thought about a "lesser grade" of compressor map. I just look at the pretty ones Garrett and Borg provide.
And like you said, it's a lot of math and time to even plot where you think you'll be on the map itself. Then as an amateur you still can't be 100% in your calculations because IMO you need to make some "educated guesses" on VE per rpm on the engine youre using it on.
And the compressor map only tells the compressor side. I tried reading a turbine map for a while and gave up.
Sometimes it's best to learn from those who have tested and tried.
You will only find compressor maps from mult-million dollar companies... and they are not very useful for us diesel guys. They are more made for all the little honda civic guys who are trying to decide what turbo they should run. Other than that they are basically a useless advertising gimic. You will not see compressor maps from smaller companies like HTT, Fleece, Danville, Barder, KC Turbos, etc...
A compressor map is also useless if you don't know how to calculate all the numbers and plot those calculation on the compressor map. You have to take A LOT of info into account before a compressor map is useful.
Simply comparing peak flow numbers on a compressor map is about as useful as comparing two engines based solely on their displacement. More displacement means more power? Right?
For example... the box s366 and box GTP38r flow just about the same when looking at the compressor map. But they are completely different turbos.
We base our research more on real world feedback and dyno testing. All of which will be presented once we release the new turbos. We are not trying to make a turbo fit 100s of different applications like honda civics, corvettes, and diesel trucks... which is when a compressor map really becomes to necessary.
Really big.
We are trying to keep this on the down low so I can't share very much right now.
But I can tell you that these turbos will be COMPLETELY different than anything else out there when it comes to drop in turbos. It will not be just a "modified" gtp38r or "slightly larger" kc38r. We will offer a few different sizes. We think this is going to be huge, but I will wait for the testing to speak for itself. I will start up a thread once this project gets a little farther along.
Are you you going to have a configuration of this new design that will be ok with stock injectors until they get upgraded?We have had lots of track/dyno numbers, I am sure I have them in my email somewhere. There are so many different variations that I will post 3 that should give the best general idea.
These are obviously +or- about 15hp, and we all know how silly it is to compare simply dyno numbers with no other variables. Some dyno numbers read crazy high and I try to leave those out of the equation. Track numbers are also useless without knowing weight/elevation.
Stock injectors - 350hp
180/30 - 420
238/100 - 520hp (but I have a few guys in the 540-560hp range)
I have a few guys running 250/200 and 300/200 but no track/dyno numbers yet.
I had a hybrid KC66/KC38r on my truck right before I sold it. It was one of the middle experimental turbos along the way. I sold it to a friend for a smoking deal because we thought the tranny was going out on it. Ended up being a faulty boost fooler. He still has the truck and LOVES IT. Best truck he has ever had, boy do I regret selling it LOL... I have even tried buying it back a few times.
The main purpose of the KC38r was to take something that already works (like the garrett 38r) and then put our own mods and tweaks to it to make it even better. This next turbo design will be totally different.
Not necessarily70mm compressor inducer at least
The largest one won't be a good match with stock injectors.Are you you going to have a configuration of this new design that will be ok with stock injectors until they get upgraded?
Send me one. I want to try it with these 350/200's that I run with my 38r and see if its actually any better.
Any news on this? Just lost the turbo in my 02 the other day.
