turbo feeler
g2shuck
It's a billet wheel s300 series that measures 72/73/t3 divided and has a 5 inch inlet compressor cover with 3.5 inch v band outlet and less than 5k miles of use has zero bearing play
g2shuck
For the right price I have a t3 divided pedestal that will bolt
To stock up pipe v band on a 6.0 and I also have a billet adapter to use the stock oil drain tube
g2shuck
Here's a peek
SSpeeDEMONSS
6mi from the beach, SoCal
I mean as the primary. Low pressure. Atmosphere. Big turbo. Whatever you want to call it. It would be in a small set of twins with a 60mm or smaller secondary. I know the turbine side is way too small but the overall size makes me think about it.
Garrett
probably getting paid at work to post this from my bionic
