Spindrift
I'm looking for the upgrades that were made to the turbo between the 2011 and 2012 model years. Thanks.
Ford supposedly "hyper balanced" the turbos from 2011 model year, in attempt to keep them alive longer.
But that is about all that I know of.
Mainly they just lowered the boost to keep from over speeding them.
I'm really not sure what "hyper balancing" is. But they can in a mass market take a shaft with turbine wheel and balance it within grams. Standard would be in per second. And in between. Then balance the comp wheel after a dull torque then balance the rotating assembly. I however do NOT see the turbo mass manufacturer taking 25 minutes per turbo to do that.... just sayin... speculating actually.... but if they do then my hat is off to them!
I can only imagine the assembly line looks like the guy at the tire shop doing a half baked balance job..
Hyper, super balance, extra care in the balancing dept. What ever you'd like to call it. That is what I was told when I lost my first one.
My 11 has over 100k & 6500hrs on it. Been tuned since 2011, has ran the higher boost h&s tune and the lower boost tune. Now running a GearHead tune. Never taken it off the high setting even while pulling 14k.
I must have a good turbo. Or its like any product that is mass produced. Your going to have your share of failures.
Sent from my SM-N900W8 using Tapatalk
Part of me wants mine to fail so I can get a new single. lol As long as it fails in town and not on a road trip.It sure sounds like you got a good turbo.
I thought I had a good one till the first one went. Then when the replacement failed in 1500ish miles of being installed, ( that one had to have been JUNK from the start, or filled with dirt or something.)
If turbo blew up on a road trip on rd trip with horse trailer, I wouldn't be a happy camper.
Actually I remember I had to drive 1 of our f550 cab & chassis 80 miles with a blown turbo. haha it smoked pretty hard lol.No cause that would suck. My first one never quit completely just had a real load howl. The second one went it went hard, lost all power, smoke, oil out the tail pipe, luckily that one was close to the shop.
yes. the cab and chassis are also geared lower.I heard off the line the cab and chassis turbo are quicker but theyes lose power at 2500 rpm because of the smaller turbo wheel.
What type of boost levels are u seeing out of yours? Guy i work with feels his should be making more boost than it is. He is only making at max 24psi at WOTMy 11 has over 100k & 6500hrs on it. Been tuned since 2011, has ran the higher boost h&s tune and the lower boost tune. Now running a GearHead tune. Never taken it off the high setting even while pulling 14k.
