torque beast
- Joined
- Dec 22, 2013
- Messages
- 375
- Reaction score
- 1
Another difference was the scrolls looked to be the same size but each side of the wheel was different size
You can be the first
Not sure, can't find the info I was reading earlier but yes it was divided and the valve is closed at idle/low rpm to direct all exhaust through one side and then open up as rpm raises to reduce bp
11-14 are sst sequential single turbos. A dual turbo run off of a single shaft. The high pressure and low pressure at driven off of the same compressor.
no, just... no.
so when you say scroll, it pertains to the turbine side?11-14 are sst sequential single turbos. A dual turbo run off of a single shaft. The high pressure and low pressure at driven off of the same compressor.
they are parallel "compressors" run together. there is no valve to switch between the identical sides of the compressor wheel
