MadDiesel73
that video looks like my truck lol at sea level
To those of you that actually know, would it be worth my time to pull my injectors (250/200) and have them bumped up like some are doing to say a 400/400 or something fairly large, while still running forged rods? Obviously de-tuned is how they would be ran, but is there any benefit of having the larger ones?
From what ive read it seems it wouldnt be worth it until i can actually use the fuel, i would suffer from a fuel mileage loss, and unless i get the tuning DIALED in really well it might be smokey.
I have run both 200 and 400 nozzles on my black truck during different stages of the project. If you are talking about making fuel only numbers, the 400 nozzle should only be used with something at least 75mm of basic wheel configuration. (maybe a gtx4294 would work but maybe not IDK). The 200s work well fuel only with the 71-76mm chargers. My 400s ran worse fuel only on my 71mm h2e than the 200% did.
Matt,
Younattribute that to the poor atomization with not enough air flow to offset it to a positive gain. What do you mean by ran worse? Down on power? Are you running them now with that new larger comp wheel and housing? That should be more then enough air flow for them as it should be over mine by a good bit.
