Up-pipe clarification woes
ToMang07
Mainah!
No t4 setup?:swordfight:
J/k tom. How's the hpop working?
Works fine, (thanks again for the help, lol) have the T500, but I think my stock injectors are getting tired.
And I think I may need to add a second fuel pump tho if I end up getting injectors. Just need to decide between large Stage 1 or small hybrids.
ja_cain
I used some hi-temp "ceramic" paint on the turbine housing, with minimal prep, like, spray it off with brake clean prep, and it stayed fairly well for about a year. Now, four years later, the paint is pretty well done.
Definitely something to be said for a professional job!
I used DEI wrap and paint, I'll try to get a pic of the rattle can if I can find it. I want to say less than a bill into the whole thing?
If it's under a hundo I'll probably have it done. That's promising your housing lasted that long especially since you probably work your truck pretty good on a regular basis. A pro job on the pipes with wrap should last a good while for me then.
