RBernardi
While putting everything together after replacing the lift pump, the bolt closest to the the turbo on the top of the up pipe would not thread in.
I took off the turbo again got a 8x1.25 tap, and chased the threads.
Started bolting it altogether, and of course the same bolt stripped out.
What do I do helicoil it?
I'm afraid if I go larger the head of the new bolt would hit the up pipe. What do you think?
If it sounds confusing hopefully I can clear it up and get some help
Thank you in advance
