Update on big blue
Shafer171
Michigan
That looks a lot like bearing material
Shafer171
Michigan
Thinking about losing the dual pump and going back to stock injectors. Not looking forward to pulling this motor for the second time in 6 months.
michaelite
Texas
Just throwing it out there but would running two pumps be more efficient and easier on the pumps themselves with stock injectors? Or is that just overkill?
bigrpowr
<How I Fly
Administrator
not worth it on stock, but is a plus with bigger because it does do exactly that , relievs the load on each pump by alot .
Shafer171
Michigan
Everyone is ok, driver of the car was sent to er but I heard later he is ok. Both pretty sore and banged up, my airbag didn't deploy.
eng53ine
Ohio
I've noticed less and less airbag deployment in newer vehicles. Glad everybody's ok.
Shafer171
Michigan
Weather turned back cold and the shop I was using isn't avail right now as well as my give a *** for working on the truck. Engine builder is going to take care of it just have to pull it out and take it to him. For now I'm taking a break.
Shafer171
Michigan
Got it pulled yesterday, only took 4 hours cab on! Engine is back in the shop going to go thru the whole thing and start back from scratch.
