Update on my rig
Lmao I'm just saying I'll take the under....
On my way to investigate that.... Lmao
I <3 Erik clausen lol
Why thank you sir!
Lol he's just a weird little Indian guy....
im way closer then shone.. he better put that ferd in the wind so he can TRY to save your soulless ass..
RedRice589
Ocala, Florida
you forget i run heavy equipment for a living... ill get through easily enough.
Heavy equipment Psh by the time you get it unloaded the state police will haul you off ***ker I'll be pointing and laughing.
after what my chiropractor put me through yesterday, ill be ok..
Chiropractors are the best. Fixed my ex-gf too you guys must have had the same treatment.... Head jammed into the headboard too many times.... :pointlaugh:
ill bring the mini excavator and park around the corner. you will never hear me till i tip your trailer over with it.
Erikclaw
Central CA
This whole valve spring discussion has me thinking. Any of you guys think too heavy of a valve spring can cause valve train failure? Big bp needs a heavier spring to compensate correct? But how much of a spring is needed and for what bp?
SEABEE08FX4
Montgomery TX
Yeah a heavier spring is needed for higher boost / back pressure / RPM applications, basically keeps the valves from either getting blown open or floating. I don't think anyone makes a heavier spring than 125lbs for a 6.4, but I could be wrong on that.
Erikclaw
Central CA
I am not meaning a higher lb spring, just want to know if anyone has done the research and or math to know how heavy of a spring is needed? I am wondering if we are using springs that are too heavy causing rocker breakage.
Six_Sloww
Southeast MI
My guess is, the only people that know for sure light/stock springs weren't good enough are people that kissed a valve. So you make the decision: possibly float a valve with a stock spring? (Potentially catastrophic) or put extra strain on the rocker with a stronger spring (crappy if it lets go, but far less damage done)
As for your situation where the entire valve train was taken out it really seems like really sh**y luck, or a screw up.
Erikclaw
Central CA
Yeah I get all that, just thinking out loud. Has anyone thrown a head on a flow bench and seen at what pressures what lb springs float or can't hold?
Six_Sloww
Southeast MI
Problem is that's a static test, it wouldn't tell you if it could close the valve fast enough at 4500 rpm so that the piston couldn't smash it.
I'm curious as well, with no aftermarket solutions for these crappy rocker arms I'm skeptical on putting upgraded springs in my 6.4
