well the motor is out of the truck, so im assuming that i would beable to do it like that, im gonna put the manifolds on an mouth the turbo, an keep the uppipes as tight to the motor as possible, but how do i make an uppipe bolt onto the 6.0 manifolds ?
You need 2 old up pipes from a 6.0 for flanges. I just bought 2 ss 90s from summit and 2 bellows, that's all I needed. I robbed the bungs from my old up pipes, and if your using a waste gate you can cut off the old flange that went to the bottom egr cooler and weld it in to mount the gate to. Mine looked good and was cheap, I think I have pics in my build thread but not sure. When I get back to my PC I will look.
Edit, I used my old up pipe flanges at the turbo also, just welded them to the new pipes.
ok thats what i thought, i wanted to make sure, idk where im gonna get the old 6.0 uppipes at lol
for the wastegate i was gonna try an reuse as much of what it has on it now, and mine will be going to a t4 flange, you used 2in stainless steel right?
an josh i can build them for a fraction of the price, an then say i built them lol
I v-band all my 6.0 manifolds. 6.4 chargers make way too much back pressure for the 2 bolt flare style of a 6.0. Other than that I reuse all the piping from a 6.4 and utilize triple layer HD bellows.
I like that. Make me mine, Mr. Papageorgio?
I have a set from Rudy's. Can those use a v band or do they have to be made special to do that?
Should be able to modify them to work.
When you use the v-band on the up pipes, what type of gasket do you put between them? The one that comes with the bands?
