Using a mini max to turn off tpms
Mikeyfitz
Houston, TX
I haven't had an issue with rotations yet, but who knows.
And SCT has an option to change air pressures to whoever said only a dealer can
Clean-15
For me there are a few reasons:
1. Every time I wash my wheels, when I bump the valve stem, air escapes. Not sure why but the sensors don't seem to be compatible with my wheels. The other day one finally tore or something and I have tape holding the stem to one side to hold air in that wheel.
2. I can't stand hitting the okay button every time I get in the truck
3. I like to run different pressure front and rear.
Jomax
Arizona
IDS will reprogram. I had front and back set to 30psi.
Sent from my SM-P605V using Tapatalk
When you plug the mini Maxx in with the tpms block, are the settings you adjust on the dash menu? Or in the tuner....
2011 f250
Tuner itself
That's the way it has been on every other truck. This one is annoying because I updated the card, then firmware and when I plug it in to the obd port, initialize communication comes up but nowhere does it mention tpms. Original race tuner
drunk on diesel
is it programmed to a 6.7 or is it unlocked? It has to be programmed to a truck. I have a street pro that I leave locked to a friend's truck for this reason
drunk on diesel
on an XRT PRO, it's the 4th thing on the main screen when it first powers up
"Tire Pressure Calibration"
