onebadcoastie
I'm curious what the problem was? Not once did I see mention of the pressure switch and if it is mentioned then I must have overlooked it. Just curious.
So you're using a mechanical gauge then? I was referring to the pressure switch that comes with the electric fuel pressure gauges. I know with my RR, if my pressure drops I either have one hell of a mechanical problem of that switch is bad.
Fuel pressure kit through my CTS monitor
I feel ya. David calls them "FASShhh fuel pumpsh"
And that should include a sensor of some sort. My point is that your indicated pressure drop may be an electrical issue and not an actual pressure drop issue. Have you hooked up a mechanical pressure gauge to determine if it's real or an electrical problem?
Depending on how old Gares edge kit is I doubt its a sensor issue. Edge is using ISSpro sensors now
