Vacuum issue?
dadada
Indiana
Had a problem back in the summer with the a/c blowing out of my defrost only. So I replaced the vacuum pump and the vacuum relay/switch next to it. Now when I start my truck it will blow out of the defrost for 3-5 seconds then switch to the vent, any ideas?
79jasper
skiatook, Oklahoma
Don't think I'd worry about 3-5 second delay. Lol
Disconnect vacuum pump, then use a tester to see if there's any slight leaks.
Sent from my SM-G892A using Tapatalk
dadada
Indiana
I'm not going to lose sleep over it but it used to never do this. A.c. would always come straight out of the vents right away.
dsberman94
Pennsylvania
Let the vacuum pump run longer before you start it. My truck always takes a couple seconds to redirect the air off the defroster.
