Nic
When replacing the valve cover gasket, what else has to be replaced with it? Any injector O-rings or tubes too?
Thank you sir!Injector o rings, and the ford kit will come with the jumper tubes, injector to valve cover seals are a good idea, depending on which side you’re doing, ccv box o rings or egr seals, the upper intake will have to come off, so intake gaskets as well. If your egr is on it, drain both cooling systems.
