05wh250
At what point do you need to ugrade the valve springs and push rods?
Yea you're right. There isn't a whole lot of talk on here about valve springs and push rods. What I would be curious to know is can valve springs be changed out with the heads still on the block?? If so are there any special tools required?? I am thinking that the pushrods can be changed out by just pulling a nut off the stud, pulling the rocker arm assemblies, swapping out the pushrod(s), and reassembling/torquing the stud nut back down.
I sure would be interested to hear more for sure.
anytime someone is going to push the envelope further than(intake,chip,exhaust) with (bigger injectors,turbo,etc) i recommend them highly.
some will agree,some will disagree. however when you have tore down as many modded engines as i have,and see some of the damage from weak stock springs and high bp,you would agree.
in the modding game,valve springs and pushrods are cheap insurance... imho
Dont do that theres a tool to take them apart
I agree. Cheap(ish) insurance. I had Elite ones in mine.
Ok good to know any recomendations?
