I'd like to hear some of your guys experiences with water meth. I have it on my super charged gas race truck, but not on my diesel. Just want to hear your thoughts as far as power increases go
I dont use meth, if used responsibly it is a good power adder, but when people get greedy bad things happen, but the water is nice to keep EGT's in check. If your interested in a kit shoot me a PM I'd be more than happy to shoot you a price.
To much meth skyrockets cylinder pressures. Just play conservative and you'll be okay. If running a bumch I'm a fan of water soluble oil getting mixed in to keep from drying out cylinder walls and other areas.
If you go to extremes it COULD pop gaskets. There are a TON of people running it just fine. If you run straight water and it uses enough water GPM, I don't know the magic number, it will wash oil off the cylinder walls. But if I recollect when this happens people are going through more water than they are fuel.
Be conservative on met 40% or less and you should never have a problem.
I have the snow stage 2 and I dynoed it once with it off and then spraying boost juice. I got 72 Hp out of it. I only run the juice on the dyno or at the track other then that I use the blue water.
