Water meth injection
strokin6L
Springville NY
Been running water injection for over 7 years....love it. I use winter blend washer fluid and mix in some radiator anti rust/water pump lubricant. Acts the same way as water soluable oil.
ajbond
For some reason I do not get the same results as Chris.. I run the -20 washer fluid and have tried straight water and doesn't lower my egts at all...??? The power is there for sure. This is with Snows mpg max kit. All three nozzles are plumbed and on their own solenoid so I can change nozzle combos for towing.. different rpms and tunes.. I can flow up to 1200ml/ min.. I also add cutting oil to my 7 gal res..
