Weird A/C issue
Jeremyleggett07
Katy, Tx.
Jut curious what u guys thought.... Was in the truck earlier today, in a center lane, and found out I had to make a right right after the light I was sitting at. So at green a jammed the skinny pedal and jumped the car to my right and made the turn. Immediately after punching from the light felt as if my truck cab temp raised 10*. All that was blowing was hot air and wouldn't kick on. I turn truck off and on, still nothing. I turned the a/c off and rose around for about 30min and the back on an FINALLY it kicked on.
I have noticed lately at times it starting to get warmer but later on it is real cold. I have tried adding freon but it always tells me I'm overcharging. Could my compressor being on the outs!?
Gary
South Lyon Mi
Typically when the A/C cuts in and out like what your describing it ends up being the coil in the clutch. When it stops working see if the clutch is working, if not see if you have power on both sides of the clutch cycling switch.
