well my buddy got a DMax
WHY NOT
Carlyle IL
turn of advancetrak and leave the shifter in D, just manually bump to 2 for the launch. it will still be in auto but lock out 1st
I don't think mine will work like that I have to put it in M and lunch in 2nd and bump it back in D right away. Justin hitting the up button just makes the gears turn off of the dash
Jomax
Arizona
That's what Sootie meant I think. You can't lock out the first gear in drive.
Cheap6.7
Rockisland County IL
I have never done this but put it in M go to 2nd gear then put it in D then launch?...
And ya with the gt37 and a 9% bigger cp4.2 maxed out is in the area of 600 ponys! With that said traction bars should be in your future.
Maybe the 15s are different but in my 12, I can have it in D, poke the plus once and it will start in 2. You can't go past two tho with the truck stopped. I would never be moving the shift lever when racing-way too much opportunity for error.
Powerstroke214
Baton Rouge, LA
Since when are they hitting 600 stock? Last I remember it was low-mid 500s with stock fuel and air.
Also, the dmax is limited by tie rods(launching), fuel and trans, lift pump means it can run 12s...well, has power for 12s LOL the trans will disagree though. Don't know if the 15s are quite on that level, but then again, since his is stock, I'd think things would be closer.
Cheap6.7
S p a r t a n did 600 and they even call the file 600 I guess. I have never seen it in person tho.
Notneb
Tell him to either race from a dig, or buy a real truck that can handle abuse...
