What are you guys seeing for boost PSI?
Mwilbur516
I'm seeing 26psi after my ECM has gone through its relearn process when I load a new tune. When I first load a tune I can boost past 32psi and hold 30psi. Then after 100-200 miles, it settles in to 26psi at WOT. WTF? No matter what I try. No leaks, this is in the computer. Anybody have any ideas? My truck did this with the stock turbo, MTW stage2, Bill from PHP's stocker and the MTW stage 1. Does anyone else see this?
EnterKO
NC
My truck does the same thing. Are you resding this from a monitor, or an actual gauge?
F-250-Owner
Masontown Pa/Maputo Mozambique
With my tow tune and the mtw stage 1 I am seeing 26 on my boost gauge and 28 on my scangauge 2 map read out.... I will drive about 2 hrs to the dyno day and hope to stop and switch both ficm tunes and my tunes from quick tricks......
Mwilbur516
I see it in a cts. My extreme street, and extreme X both do this.
So even with Innovative tunes you're still only seeing 26psi? Thats interesting cause it seems everybody has the highest boost numbers on I.D. tunes. Thats partially why I started this thread, I'm on the fence about weather or not an I.D. tune might solve my problems.
EnterKO
NC
Read some threads that pointed to the egr needing to be plugged-in to properly utilize a tune. I dont have mine plugged in any more, thats why I asked.
EnterKO
NC
Technically I can see 27 but it doesnt seem right, that's stock and with a batmowheel
