earlybroncoboy
What fluid you guys running in your zf5's. just put another trans in my truck when i did the clutch job do to a broken ear for the Slave cyl. It is a bear to get in reverse some times it will go in 5 times in a row others just grind or pop out. and 2nd to 3rd grinds in higher rpms. I read that some people put in RP syncromax or red line mtf and it fixes it. Others say only use synthetic atf. I put 4 quarts of Amalie universal synthetic in it. I know being a feramic dual disk might be a bit to ask from the syncros. just wondered what you recommend for fluid.
