What is this noise
Cody1898
This starts right after start up and does it the whole time the engine runs. Drives me crazy and I have no clue what it is. The video is a little long. It’s does it after the engine is off for 20 seconds or so
https://youtu.be/uTo7W28ZNN8
that is the wastegate solenoid for sure. There is a TSB about it but ford says the noise is normal lol. I am running a 15 style turbo on mine so i dont have a wastegate anymore therefore i just unlpugged the solenoid and i dont get any codes and best of all no annoying noise.
its located just underneath the hot side pipe.
Cody1898
I just upgraded to the 15 style turbo myself and removed the egr. Trying to track the noise it sounds like it’s coming from under the fuel filter housing on the motor
15s don't have a gate?
Mesa, AZ
Ford does not say its normal. Tsb is to replace the wastegate solenoid vacuum harness.
Powderhound
I just had this exact issue a couple weeks ago.
They are correct. $45 part
About an hour install with no special tools needed. Just small hands that can get back into the wastegate to install the larger vac line, wicks cured my issue.
