what oil you runnin?
bruce
Middle east
I can get schaeffers 9000 cheaper than t6 from Walmart. I can do an oil change for 100 bones with a motorcraft filter.
Austin, Tx
My truck exclusively ran Delo 400 it's whole life until recently. I switched to Motorcraft. It seems to like the Motorcraft better. Cold starts seem to be a little better and it definitely runs a little better. I had to change the oil at 3000 miles with Delo every time b/c it started to run a little bit rough and I could tell performance was down. It would even start dropping ICP a little bit.. So far I haven't had that issue with Motorcraft. The only reason I switched is b/c the store I get my oil at only had one gallon of Delo left and had enough Motorcraft. Think I paid like $20 per 1.25 gallon jug.
neverkickn
AR
Schaffers 7000 runs me 98.63 for four gallons and 9.99 for a motorcraft filter.
I have delo 400 in mine right now as it was leaking too bad to put anything fancy in there. Somebody mentioned that delo 400 is a blend. I don't think so. I'll have to look tonight. I believe the isosyn on the label is them claiming that it performs as well as a synthetic. If they are pitting it against rotella I'm sure it does perform better. So would 3 in 1 oil.
