What to do?
TripleE44
Keller, TX
They love to give tickets here for window tint, and I bought the nightshades stuff for the lights, but it doesn't spray well cold, but im thinking of the recon markers and led tailights
Recon for the markers for sure. Mine with niteshades made the light look red, which is not legal to have facing front on your vehicle.
For tails, I bought recon clones on eBay really cheap. They ended up looking the same, but the lense wasn't as dark as the recon. The inside face is identical from what I can see on pics of the recons. I ended up using niteshades on my tails but just a little so they're just dark red. It's a really clean/classy look in my opinion.
I also sprayed the tails when it was a little cold out, I think like 50ish. I found that it came out better if you play with the distance. I got about 4-5inches away and it came out great.
6.4psd916
Roseville , CA
Thanks, might give that a try, What do you guys think about exhaust tips, with the 5in flo-pro, do you think the 5 to 6 mbrp black 18in with rolled tip or 5 to 6 mbrp black 12in dual wall? Im thinking the dual wall. And I was thinking of doing the dpf back part of the exhaust with black engine enamel, what do you think about that? Will it withstand the heat?
6.4psd916
Roseville , CA
None soo far, the system is painted satin black with engine enamel, so it looks okay at the moment going to get some pmfs next, shifting is rough and the rear end is all over the place
