under pressure
- Joined
- Oct 4, 2012
- Messages
- 575
- Reaction score
- 0
Only 900 bucks !
Doesnt turbonetics position their mounts a good bit further forward to the intake-y than most other custom t4 mount builders?
the blanket helps hold the heat in the exhaust housing for faster spool up...also helps keeps under the hood temps down and protetcs that fuel line on the pasanger head from getting hot.....Must be why this kit comes with a turbine blanket.... about 100 bucks.
Just a sexy bunch of parts.
I bought my kit from unlimited diesel (a sponsor here) my kit came with braided lines and plenum inserts..I don't see them in the link above... it was also 150 bucks to ship..that was last April..I'm glad unlimited shipped for free...all and all for what you get in this kit..i think this kit is well worth it...if you dont want the full kit..unlimited can sell you this kit with out the IC pipes and other toy's for a little less $$...send them a PM and ask..So do you think this would be a good kit to consider buying or not?
are new i/c pipes included?Yes i no, i was looking for the T4 info. Thanks.
Add a S366 and ur about 1500 bucks if the hot side IC pipes lines up.
comes with the cold side.. you need to use your stock hot side with the adapter pipe that comes in the kit...the picture below shows the kit on a motor how ever the picture shows un polished up pipes..the kit does come with polished up pipes..are new i/c pipes included?
sent by the beard
