What's this sound like?
Six_Sloww
Southeast MI
So my tired 6.4 knocks from time to time, it's a high pitched knock, and the strange thing about it is it goes away completely.
Sometimes it only knocks under light load and a snappy rev, sometimes it does it while idling and sometimes it just sounds like a happy little engine.
Here's a vid:
http://youtu.be/crr_q60Bg08
Six_Sloww
Southeast MI
When I looked up videos of worn rockers they seemed to make a lower pitched popping sound. This is almost like a slap or a knock.
Fwiw, I think my injectors are going bad. I'm not getting contribution codes but it does miss a lot
Six_Sloww
Southeast MI
The more videos I watch the more I notice this being considered "normal" sorry if this has been beat to death, I just thought it was odd this "normal" noise comes and goes as it pleases..
Powerstroke Man 6.4
All my 6.4's do that when you rev it up and let off.
Six_Sloww
Southeast MI
Thanks for confirming... 251k and counting!
I think I need to man up and put a 5" on this thing so I can stop over analyzing every little engine noise
webb06
Seneca, MO
Definitely sounds like rocker arms to me. Have you had the valve covers off to inspect them?
Powerstroke Man 6.4
80,000 on the F-350 CCSB DRW 253,000 on the F-250 lariat and 261,000 on the F-250 FX4 still going.
Six_Sloww
Southeast MI
No, and I'm sure if I inspected them they would show a lot of wear.
It seems odd that this "normality" is different from motor to motor. I'm not ruling out other possibilities, but it seems like there's a lot of 6.4's out there making this same noise.
webb06
Seneca, MO
I changed rockers today on a 6.4 that had 120k on the engine. It's been deleted for some time as well. It was a work truck so I'm sure it had a lot of idle time and regeneration time before being deleted. The swivel balls on the rockers were completely flat on all of them.
Six_Sloww
Southeast MI
Either mine have been replaced or they will likely be falling off soon here.. My truck had a dpf until 230k.
Is it worth trying to get to the rockers cab on? Or even possible for that matter? Tough to find a hoist I can tie up around here. Unfortunately there's no money to pay someone to do it
webb06
Seneca, MO
Rockers are cake cab on. They aren't like a 6.0 where they are secured by the head bolts. Remove valve covers, injector jumper lines, fuel rail, then the rockers and pedistal. It's cheaper if you buy the full assembly for each side. Somewhere around $250. Plus the new injector line kits. Might also have to replace the valve bridges if they're pitted.
Six_Sloww
Southeast MI
Well that's good to know.
Stroked777
Casper, Wyoming
I'll be doing my rockers here soon, how long did it take you and what did you take off the top of the motor to make it easier to do? I looked and the pass side looks the easiest, just not sure what I have to take off to get the driver side accessible
I got my rockers from sunrise ford for $380.96 for both sides. But it got here and all the clips were broken
webb06
Seneca, MO
Probably 4-5 hours. I work on power strokes everyday though. Passenger side is cake. Remove the intake and the valve cover is right there. Probably wanna pull the coolant hose going to the heater core off as well. Be careful with the plastic part of the line. Drivers side, remove the battery and drain the coolant and remove the reservoir. Remove the turbo "U" pipe and fuel cooler as one assembly. Then the valve cover.
Ya the rocker assembly I received didn't have any broken clips but a few were laying loose in the package.
boggerr
Barnegat, N.J.
If you have a stock air filter take off the cover and listen for any popping thru there. Mine had that tick too and slight popping thru the intake.
I made the mistake of watching videos and hearing " that's what 6.4s sound like". Well, that left me on the side of the highway with a broken rocker arm.
Stroked777
Casper, Wyoming
Well as Webb said, pass side valve cover is easy enough to take off, why not remove it take a peek, if the look bad on one side, I bet you a donut they are bad on the other
