Wheel bearing...
Strokin6.4
Started to here some squeaking while making a hard left turn from a stop today so I looked it up and saw a hub assembly is going for about $500!!!! You you change wheel bearings with these trucks or have to replace the hub. Thanks!!!
tensixniner
Lots of things can make squeaking noises in the front end, basically anything that moves.
I wouldn't jump to wheel hubs without more investigation, like you said they're expensive. Might just be the brakes.
TripleE44
Keller, TX
Mine did the same thing. Started out only while turning and within a week it did it all the time. Turns out one of the caliper pins was stuck and the brake pad had worn sideways. Replaced the whole caliper bracket or whatever it's called, the pads and all was well again.
Strokin6.4
It does squeak a little at low speeds. Ill pull the wheel off and take a look. I had this happen on the back. But it was more of a burning smell lol so it could just be the pads. What's a good brand for low dust?
6
6.4stroke
Guest
Bad rotor mayb or metal on metal which there be no brake pads left. Had the samething happen to my truck piston broke on caliper.
