Wheels and track bar torque specs
TTBOOST
Moline,il
I just installed a set of fuel wheels in my truck and the lugs are the acorn style instead of the flat stock lugs. Would I still torque them the the stock specs? Also I was wondering how much to torque the track bar and radius arm bolts at the frame. The instructions on the ready lift kit and what I’ve read else where is conflicting. Thanks in advance
If you have tapered lugs, make sure the rims have a matching taper to accept them or you have the wrong nuts. Track bar bolt on the frame side is 405 lb ft
Sent from my SM-G955W using Tapatalk
Hoosierdaddy
The torque on the lugs will stay the same, I believe 140 for your truck. You’re torquing to set the studs to a certain yield regardless of lug type. I believe the radius arms are 250. Like Sootie said, use appropriate lugs for the wheels and make sure you torque the trackbar to spec. The 405 is for the end on the driver side, not the knuckle.
