Where to buy locker
johndeerezach
wellman,IA
They are some cheaper to and No maintenance makes it good choice as well. Is it true u can get an aggressive one like said in the other thread
Sent from my SCH-R970 using Tapatalk
johndeerezach
wellman,IA
So I'm ordering the truetrac from summit and making sure these have 35 spline axles I can't find anything that says the door has a 31 I didn't know if that was for the front or rear. Thank you
Dieselboy.
Surrey B.C.
Tru trac will be what my rear end gets. The stoker is toast.
I took a gamble on the front. Went with a lockrite. See how it works. Just didn't want to pull the carrier and ring and pinion.
johndeerezach
wellman,IA
So rear end is apart but have to get the bearings and seals replaced since they look worn. 186xxx I figure that's pretty good
