Which coil Springs to lower 06 f-350?
MorganM
SE Houston
I have a custom pair of front coils that will net 3" drop. I had them made for a '12 4wd, they rode well but occasionally hit the bump stops- looked awesome though. They are wound to a stock spring rate to avoid sagging over time.
$125 shipped, if interested, send a PM.
Sysx
Hampton, Virginia
Will going from a 5250 spring on my 08 to a 4800 spring get me about 2" of drop?
ihpower_6oh
palmerton pa
U 08+ guys running the 4800 springs up front n no block in rear. What size tires are u getting away with. I have wheels n tries on the truck with a slight lift front n back n would like to switch it up but still use the tires I have now.
MorganM
SE Houston
I'm using a 305/55/20 on Platinum wheels with no rubbing. I'm also lower than a truck with 4800lb springs and rear blocks deleted.
Sysx
Hampton, Virginia
Sits lower now but 305/35/24, dream beams and 4800 springs.
Finally from a phone that fits my hands!
MorganM
SE Houston
MorganM, do you still have those springs and do you have any pictures of them installed?
Yes- I do still have the springs.
Just FYI- the ground here wasnt level and made the truck appear to be much lower in the fron than it acutally was. It was closer to level on flat ground.
