Hello, I'm looking for any year fuel pressure off an obs stroker. If you have a fuel bowl laying around, the pressure regulator is probably attached to the side of it.
The superduty ones are different. But it may work for my application, I'm just haven't got my hands on one to see. I am doing the tightwadmod because i dont have the coin for A 150$ fpr. http://powerstrokenation.com/forums/showthread.php?t=102394
So as long I can adapt the two high pressure return lines to the sd regulator, and then send the low pressure bleed off back to the tank it will work fine for me.
If you have one can you put up some detailed pictures?
I can look for that sd one i have this weekend if ya want. I think its different tho as i was gona put that bowl on for some reason and it wasnt the same.
