Your EGTs, Please.
e.nickkk
I have powermax 175cc injectors steed speeds 2 1/2 uppipes ported intake tsd tunes i run 700 to 800 at cruising speed from 30 to wot the most I c is 1100
the chad
190/75s, stage 2 mtw. Sit at about 700 @70. And 1500 WOT with xrace and ficm tuning...my truck seems to run cooler than what ive been reading?
turbotibbo
stock injectors , 10 blade 03 turbo , str8 pipe , cold air intake h&s wild tune 58 volt ficm , wot 1450 max, rolling at 30 650 and 65 mph cruzing is about 850 900
ODAWG714
Orange*County, CA
Gear head/ super panty dropper/ dfuser race can't break 1190
Pmax,airdog150,Afe intake, steed speed manifolds,elite up pipes, 4in exhaust, 35in tires 4.30 gears. Egr is shut off cooler capped
EnterKO
NC
Stock injectors, 4 inch down pipe to 5 inch straight pipe, industrial injection stage one hybrid, extreme street. Cruise at 55mph at low 500s, gets around 650 in the hills. Pulling trailer today with tow small kabota tractors with loaders and grader blades, stayed around 600 to 700 cruising at 55.
:bs:
Pizza pig
MD
EGT readings like this can be heavily skewed by placement of the probe. It has to be in just enough to get the correct reading. Put it in too far, or not in enough and it will read much different. My readings also were way different when using glowshift to autometer gauges.
Needless to say, on flat ground with cruise set at 68 mph im at 700* with 205/150s and a 66mm non vgt, up hills will climb to 1200. I usually see 900-1000 due to the hilly Connecticut.
little luke
Union County, Kentucky
Which part?
Under 35 percent engine load with the trailer loaded it got up to around 875, never did get past 900. 40 percent load from 0 to 55 hit 750 then backs down to 500-550. I never have seen over 1000, but I've only had the egt probe in for a few weeks. Cruising with the trailer is at 24-27 percent load and no trailer is 19-22
weazel
Elkview WV
Which part?
I run higher than that unloaded, hauling nothing bit air
Translated from hillbilly, with tapatalk
Engineers clear the way!
SSpeeDEMONSS
6mi from the beach, SoCal
03, stock Injectors and turbo. 4" downpipe to 4" straight. Stock intake with zoodad. 35" MT's. Isspro gauges, probe in the drivers side exhaust manifold right at the bend. Cruising always seemed right around 100* per 10mph over 60mph. Don't remember boost. WOT would bury the needle so 1600+. Probably 1800+ on long runs. WOT boost was 32-35psi.
Garrett
encrypted with an enigma machine
little luke
Guess I'm going to check my probe. I agree with y'all, my egts are to low.
