Your trucks transformation
webb06
Seneca, MO
:whs: curious for future reference when I do pull mine..... :
Most lift arms also don't go short enough to lift on the pads when doing a regular cab. I have to actually lift on the arms and barely miss the bed in back and it's very close to hitting the frame up front. I also use a ratchet strap if it seems like its wanting to fall forward.
RSK
Connecticut
100% stock...
smoked tail lights should be on the way soon, fender badges should be done by the weekend. and LED head lights have been ordered and should be here saturday or monday. and there is much more to come, but i have only done stuff for the exterior of the truck, so i need to take a break from the exterior and do some mods under the hood!
MSTR-P
Maryland
The first is when I bought it and the second is how she sits now.
Brody_nr
From bone stock to Project NIGHTLIGHT
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Brody_nr
Im not done with them this is a test headlight to see if an what all I could do im gunna use spots as my low beams and floods and the spot as my high beam
Brody_nr
And i put switchbacks for my running lights/blinker
Brody_nr
Sqitchbacks for running lights
Koda22
Ruidoso, NM
What kind of kit are you using for the wheel lighting...I keep thinking about doing something like that
Brody_nr
The 4 in round leds that they use normally to replace fogs
Brody_nr
These
