Baker42
Thanks maybe if I asked what phone you have I would get an answer.
When did ford ditch the dual mass flywheel?
Sent from my SM-G900R4 using Tapatalk
single mass flywheel will make this sound. i have a valair single mass with ceramic disk and at certain times like when you lug it down past 1k rpms it will sound like gears grinding. if this is what you think might be the problem don't worry about it
http://www.valairinc.com/performance/7394-98.html
take a look at velairs site. note that it says some trucks not all so that may be why the other trans didn't make the sound
Most important question yet: DO YOU STILL HAVE A STOCK DUAL MASS FLYWHEEL?
If you do, most likely it is self destructing. They have been known to break tranny cases due to vibration when they are really bad.
Can make all of the symptoms you have described. I have run a lot of ZF5's hard and never lost the bearings. Not that they cant be bad, just likely something else.
What flywheel do u have
So it is a farely new flywheel?
Looks like people were trying to answer your question a few times.
BTW, I have a Iphone.
